Change it. Just put ".tun" after it I stead of ".ctz". Or open it with v8 then go to edit and it will say edit in v7.5.
It has security options that i can't remove
can't do that if tuner locked....
If it locked like that it needs to be in v8 then. I assume you are using an autocal then? Pass through flashing?
Sent from my iPhone.
V2. I got it flashed, i called ATP and they had me pull the ABS fuse too. I pulled, radio, radio amp, info, and ABS. Had the first 3 pulled, and after the ABS was pulled it flashed right on. :woott:
Good to know.. did you get my voicemail buddy?
yessir im on it :thumb:
You da man! Let me know if u need a flow sheet. David at dts told me to say HI :thumb:
There has been issues in the public release software for LLY flashing via V8. These have been fixed in the March software releases. Please make sure you are running the latest release posted yesterday. http://forum.efilive.com/showthread.php?22369-EFILive-RC-2-(March-28-2013) (although it was fixed in the earlier release made this month too)
As already mentioned, if your controller was previously locked, you will need to unlock it to gain access to flash it again.
Cheers
Cindy
