Can I twin
blue09dmaxx
Too broke for this shit
Jan 15, 2012
823
The south
Currently I'm running a single s366 double batmowheel 66/74/91 t4 on a non gated rdl pedestal, can I twin it with a s483 or 480 or am I gonna need to redo my current setup
S Phinney
4,008
Quncy, Fl
so just get a new pedestal or put a gate on mine and ill be ok?
You would need a spacer with gate or a new pedestal with gate built in. It depends really on what items you have but most can be made to work out fine.
5,818
If im thinkin about this right, it wont hurt anything but it will be lazy at lighting and will porbably not produce as much boost as it should all around
S Phinney
4,008
Quncy, Fl
The gate is used to adjust boost between the stages. You don't want to run the top charger at possibly full efficiency or past and not use the atmosphere stage to its potential.
Noreaster
2,910
Cape Cod,MA
just get a gated pedestal, better off with the external wastegate than the internal gated t3 housing meant for a cummins
