Cam shaft torque spec missing
ikeG
Oughta Know Better
Apr 19, 2011
2,456
143
Western PA
www.facebook.com
I cannot locate the torque spec for a lmm fastenr. It's the six bolts that hold the tin plate to the cam gear. I'm assuming they're calling the two Allen's the cam thrust plate bolts, the two that hold cam in block. Then there is the exciter ring bolts, sensor bolts, and the gear volt but they don't mention these 6?
Oct 16, 2008
948
12
Idaho
I have it as, camshaft exciter ring bolts- 80 lb-in. Camshaft position sensor bolt- 89 lb-in. Camshaft thrust plate bolt- 16 lb-ft. Camshaft gear bolt 173 lb-ft.
