Caltrac install tips
1,849
Just my observations. Install was straightforward, but none of this was covered in the instructs or online.
1) Take the hitch off before you start. Easier to remove rear spring bolts that way.
2) You'll have to loosen the fuel tank to do the drivers side, so make sure you dont have a full tank. :eek: You cant get the front DS bolt out if the tank is solidly mounted.
3) Easiest just to take the springs out to work on them. Heck, you're only one bolt away....
4) Easy way to remove old bushings without using a press (took about 15 minutes/side):
a) Use air chisel to "fold" the lips of the outer side of the bushing inward to its center.
b) Spray a bit of lube around the exposed bushing sides.
c) Pound a screwdriver or chisel into the space between the spring and the eye to use as a wedge to spread the eye open just a bit.
d) Use a handsledge and a 34mm socket on the folded-in side of the bushing and pound it out. I used a 36mm socket and it was a bit too large.
e) Dont use the sledge directly on the aluminum bushing to install. I used the large socket as an anvil and pounded around the edge of the socket to squarely push the bushing in. I also used a small bit of antiseize on the bushing. Worked great.
5) If you're planning on removing leaves from your springs while you're installing the caltracs, make sure you have 1" shorter grade8 bolts or springpak pins to replace the OEM ones.
6) I tightened both Ubolts at the same time to keep all 4 nuts equal on the bolts. I figured the bolts may "twist" if one nut was tightened farther than the other.
7) Not sure if this was necessary, but I jacked the axle up to add some preload to the bushings before I tightened them down.
8) Torque specs:
a) Front spring bolt -- 110ft/lbs
b) Rear spring bolt -- 70 ft/lbs
c) Ubolt nuts -- 110 ft/lbs
ON EDIT:
9) You will probably have to trim the sides off the plastic spacer on the front of the second leaf of the spring so the caltrac pivot can move freely.
10) Dont be surprised if the two sides arent threaded exactly the same when you fit the bar to the bracketry. My DS is fully screwed in, and still the pin rests on the spring, while my PS is threaded out about 1/4" just to make contact. I checked, and my axle isnt tweaked...truck isnt dog-tracking. Very odd...must have something to do with added weight on DS (fuel tank), same as the torsion bars.
Hope it helps someone.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
just my observations. Install was straightforward, but none of this was covered in the instructs or online.
1) take the hitch off before you start. Easier to remove rear spring bolts that way.
2) you'll have to loosen the fuel tank to do the drivers side, so make sure you dont have a full tank. :eek: you cant get the front ds bolt out if the tank is solidly mounted.
3) easiest just to take the springs out to work on them. Heck, you're only one bolt away....
4) easy way to remove old bushings without using a press (took about 15 minutes/side):
A) use air chisel to "fold" the lips of the outer side of the bushing inward to its center.
B) spray a bit of lube around the exposed bushing sides.
C) pound a screwdriver or chisel into the space between the spring and the eye to use as a wedge to spread the eye open just a bit.
D) use a handsledge and a 34mm socket on the folded-in side of the bushing and pound it out. I used a 36mm socket and it was a bit too large.
E) dont use the sledge directly on the aluminum bushing to install. I used the large socket as an anvil and pounded around the edge of the socket to squarely push the bushing in. I also used a small bit of antiseize on the bushing. Worked great.
5) if you're planning on removing leaves from your springs while you're installing the caltracs, make sure you have 1" shorter grade8 bolts or springpak pins to replace the oem ones.
6) i tightened both ubolts at the same time to keep all 4 nuts equal on the bolts. I figured the bolts may "twist" if one nut was tightened farther than the other.
7) not sure if this was necessary, but i jacked the axle up to add some preload to the bushings before i tightened them down.
8) torque specs:
A) front spring bolt -- 110ft/lbs
b) rear spring bolt -- 70 ft/lbs
c) ubolt nuts -- 110 ft/lbs
hope it helps someone.
sound like everything got covered, thanks tom
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
nice. since I have a transferflow tank, i just cant drop mine even when empty. i cut off the drivers bolt on the non threaded part and that cut like 3/8" off the length so i could get it out of the way.
nice writeup Tom.
1,849
Nope...no pics during the job. Nowadays, projects take me long enough without stopping every couple minutes to take a picture. :)
1,849
First pic of old bushing. It better explains how I folded the lip inward. Id LOVE to know how GM installs the bushings in the first place. Must be they fold that lip over after install to hold the bushing in.
Second pic shows the hex end of bolt that Honda cut off, and how bushing should look installed. (yes, my frame is rusty)
Third is finished pic. Ready for the 20th!
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
What happend to the pics :confused:
edit: yes I see there was no original pics. But this qoute made me think someone had them
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
Those aluminum bushings sure are hard to get in there. Was it pretty easy to get them in when the leaf is out of the truck on solid ground?
x2 Curious as well...want to get these on tomorrow as I'm heading up to the NHRDA event in NorCal on Friday and would like to get these bad boys on before I make my passes
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I burnt and drilled the rubber bushings out, then with a sawzaw I cut a line on the outer part of the bushings and pryed them out. That was the easy part, theres no way to get those babies in with the tools I have at home
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Thanks for the torque specs Tom. I just went ahead and bought a bolt to replace my drivers front. I knew I'd just cut it to speed things up.
I pressed my bushings in with a bench vise w/ some anti sieze.
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
I should have a decent advantage then as I am stationed on a base that has a full hobby shop with a press just not sure cause I've never done it myself and pretty much have to have it done tomorrow that way I can go to the races...they're 8 hours away haha...
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
fwiw everything else during the install is a breeze, after I got the leafs back it took me like 20 minutes before I needed the torque wrench to finish everything up
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
nice...good to hear man. Just gotta get those damn bushings out and in with the new :) any advice to setting them? I know the instructions say start parallel to the ground but how exactly do you adjust them?
