Calculating compression ratio
13,765
834
I'm looking for some information. How much volume do you remove from a piston if you cut the lip off? What if you shave off .040"? Do LBZs use A or B grade gaskets stock? Based on some really rough calculations:
With a C grade gasket I'll be running 15:1 CR
With an A grade gasket I'll be running 15.3:1 CR
With the piston de-lipped and a C grade gasket I'll be running 14.4:1 CR
With the piston de-lipped and an A grade gasket I'll be running 14.6:1 CR
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
it can depend which gaskets each engine gets....some get A's, others get B's, etc.
some even get different gaskets per side. (im almost positive)
Id like to know this too...Im running C gaskets and the lip cut off of LB7/LLY pistons, with a .187" radius...
ben
