Question: CAD Software
BlakeN08
Dec 9, 2008
13
Macclesfield, NC
It's definitely not free or inexpensive but I believe the best 3D CAD software right now is SolidWorks...I used it for a couple of my design/engineering classes and its a pretty amazing program.
Redbone
but this one goes to 11
May 1, 2008
261
Indy, IN
I'm using a trial version of Alibre right now. My brother owns an industrial design company and they use Solidworks exclusively. He played around with the Alibre demo and was very impressed. It runs $398. His Solidworks annual maintenance fee is like $3000.
BlakeN08
Dec 9, 2008
13
Macclesfield, NC
Yeah we have a university license so I can have it on my laptop for free as long as I'm a student...There are plenty of 3D design software choices out there, its just a matter of what you are looking to do with it. Most all will probably be good for 3D modeling its just a matter of if you want to take it farther than that or not. Do a search in google and you can find a lot of reviews and comparisons on some of the top CAD software...
Chris611
134
Knoxville, Iowa
I've used SolidWorks for years at work. I've used Pro-E as well. SolidWorks is a good program. For every liscence that a company purchases, SolidWorks allows them an "at home" liscence. If you ask around, you may be able to find someone with the disks that will let you load the program for free.
rumblebee1967
Oct 1, 2009
not sure what you need it for but take a look at google sketch up. It has a free and a pay version. works pretty well
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Thanks for all the input yall! Hopefully soon, and with a bit of practice, I'll have some solid pieces to try out on my truck.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
i didnt see it mentioned but i used Autodesk Inventor which is simmilar to Solid works and i liked it alot.
Autocad was good for arhcitechure stuff but for 3D rendering parts and misc items it wasnt good because of the editing abilities like solid works or autodesk inventor had. Though the last version i used was in 2006 they might have made it better
jlawles2
1,057
Danbury, TX
If you are doing CNC work, Check with your friend to see what he is using to do his CNC programming. You may be able to get a copy from him. I think both are using hardware keys, but check around, they make "sharing" programs for network use.
There are programs like Mastercam and Alphacam that allow design and such, and also write the G-code for CNC machines. If your friend is using one of these, then it is a no brainer for transporting the 3D model to him. It also makes it easier for him to change the Z-height and such if you set it in the wrong place. I have been running autocad for about 10 years, and integration to CNC software takes practice to get it right.
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
X 2 above. Many of the Post Processors (that is Software that takes .dwg .dfx type files), and changes them to "g" code which is the software language that CNC's use will in fact have design abilities although i do not know of any that provide 3D, those that I am familiar with typically only provide std 2D imaging. that includes SigmaNest, Columbus, MasterCam.
All of these programs do in fact require "dongles" which not only are the physical keys that open up the software, they also limit the # of users allowed on a certain software suite. Having sold more than one ESAB Cutting Machine in the past 10 years, this aspect is one that I make sure I inform prospective cutting machine customers who would normally figure: "hey I bought the software, why do i have to pay for another liscence just so that both of my draftsman can use it.??" I got caught that way once..now I let em know up front.!
If you do in fact find someone with a home liscence for Solid Works...PM me. PLEASE..!! I have a very interesting Solid works file that may interest you..!
Thanks,
stk
Osubeaver
Professional Grade
Aug 30, 2008
696
Oregon
Actually you can buy Mastercam Design LT, that does not use a dongle. It's around $300 last I checked..probably more than you want to spend still. While it will do "3d" wireframe and surfaces. It will not do solid modeling like the full product Mastercam solids add-on does. And it won't create any toolpaths or generate code. It will read most standard file formats (SAT, STEP, IGS, X_T, etc.), as well as native Solidworks files (.sldprt, .slddrw).
http://www.mastercam.com/LT/DesignLT.pdf
Even the full product, while it will do solids, is not a parametric modeling system like a purpose built CAD system. It will do anything you want with solids, just gets really cumbersome sometimes if you try to get too fancy with it.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Surfcam allows 3D design. Solid Works is the best CAD software right now, not counting the high end stuff like Catia and such.
All CAM software can read dwg. and all CAD software can save in the format, so whatever you choose won't have much problem posting a program.
FWIW you really need a CMM to make (reverse engineer) parts for these trucks.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
I should add, CAM software is a PAIN in the ass in general. Most of the generated tool paths are loaded with excess moves and a bunch of just shit in general.
Rant over.
You should be able to find Solid Edge v20 for free on the net somewhere. It is also decent CAD software. You will need a crack for it though.
13,696
747
I was about to ask about this software. I just started working with this some at school this semester. Is it any good? How similar is it to SolidWorks? Sounds like SolidWorks is a much more common modeling software. Is there much of a learning curve to go from one to the other?
