buy the new hydraulic mounts GM uses on the trucks now rides 200% better UPPER 25971031-need 2, LOWER 25791032-need 2, Washers 15854745 need 2 if yours are crap. You know maybe Henry can help order them up for you thru his GM slot. These take that axle wrap down alot which is great on the cement slabs and even racing some.
They're for front and back those are GM #'s if you have to look to know something. It's from people who have done it and bought them. Christ!!!!!!!!!!!!!
So new hydraulic in the back and factory gm front? Only my front one is shot but I guess I should do them all.
I will probably try the hydraulic ones and seen how that goes. Just to double check they only fit the rear?
Oh, well shoot. I gotta try em out! I'm 99% sure my truck is blessed with the "frame beaming" so maybe they'd help?!?!
Anyone care to give an update on using the hydraulic cab mounts? Especially on the earlier models. My 02 has the "hop" between 45 and 50 so I'm wanting to know if they're worth getting.
For my truck and the issue I was having it fixed it, they are spendy but my ride is so much better now I was kinda surprised they worked.
But then again look at the difference
OregonDMAX, are these the correct and current part numbers?
Thank you..:thumb:
