I'm looking to do a set of cab lights on my truck, I want to run the factory wire harness but I don't have lights now. My question is should I look for a set at the junk yard or would I be okay running a recon set of lights and the recon harness?
all it will be is a single wire up pillar to lights, then just tap into light source, pretty simple. I switched my stockers over to recons and found my truck never came with lights from factory and all that was ran was a single wire up pillar. If you use recons use a healthy amount of silicone on the seals and holes.
