cab heater core
duurtymax
May 13, 2017
Hi guys, has anyone had issues with their heater core plumbing nipples failing? One broke on my '04' and I'm wondering/hoping I don't have to remove and replace the heater core to repair? Has anyone had to deal with their heater core, repair, replace etc? I bypassed it roadside temporarily to get home but really want my heater back, it's chilly out here these days. haha
I searched here and other forums but no apparent threads on this type of issue.
thx.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
It's just a quick disconnect fitting, I've had 2 trucks that have broken them. Drain some coolant, pull the heater hose clamp off, pull hose off, and use Q/D tool to remove fitting then install new one.
1,936
Well, its good to know those things can be replaced. I think Id rather just remove the plastic and clamp the hose around the pipe itself, if that was an option.
3,728
297
I suspect it would be possible, but you'd have to verify hose diameter. I think they're a vestige of the shared platform with the Tahoe/Suburban, which has the rear heater lines T in at those fittings. That would let GM keep the hose length identical between the truck and SUV.
Though I question if a quick connect is cheaper than dealing with 2 hose lengths... But GM did some interesting things in the GMT800, many of which have contributed to its long useful life. So I'll forgive them the occasional weirdness like this because we get plug and play operation of nearly any combination of modules my heart desires. Quadrasteer AWD Duramax Suburban? Yep, plug, minor tuning, and play!
duurtymax
May 13, 2017
I was able to remove my plastic quick clamps with a 3/4" disconnect tool like whats used on the fuel lines (mine is a Lisle p/n-37000, pkg of 6 sizes) it seems the nipple the plastic clamp attaches to is 5/8" o.d. and the plastic barb is 1/2" so in order to attach the 1/2" rubber coolant line to the alum. core nipple you will have to stretch it over the 5/8" nipple which could create another problem down the road should the rubber line split from age and tension etc.. I've relented to just replacing the plastic connector and hopefully being good to go for another 14 yrs.
I would recommend first cleaning the area good if yours happens to be caked with dirt etc. from your use environment. Then prior to inserting tool rotate the clamp a couple times and push it back toward the firewall by hand or pliers, then insert the tool working it into the back of the fitting. You may need to wiggle the fitting slightly to help the tool start as your pulling tool into the fitting with your finger tips compressing against your palm/heel of hand (unless you happen to have some kind of handy dandy tool that would fit around the tube and compress the tool into the fitting) hand/grip strength is very helpful here and mine is for shit so it took a while along with the customary cursing etc until being able to fully bottom (aka balls deep) the inserted tool into the quick conn. fitting. The inner most core barb is pretty easy to reach to/around etc. the other one, the basstard leftist that it is, (political humor) is a little more difficult due to it's position between the other barb and close proximity to the angle of the firewall but it's still doable just takes a little more patience. On this one I had to sand the inserting edge chamfer on the tool to a slightly longer angle to help it get started. Once the tool is inserted and tabs released pull-n-twist on the connector only.... until removed, leaving the tool in place, then remove the tool. There is a alum. sleeve ring that
is on the nipple that the tool hangs up on. When installing the new Q. Conn. it would be a good idea to lubricate the internal o-rings and alum. nipple with trans fluid or some other lubricant that will promote o-ring life and prevent potential damage to o-rings during installation. For the efficient worker it would take about a half hr. to complete, it took me a little bit longer. Good luck, I hope this helps somebody, happy motoring and HAPPY NEW YEAR!
