Allison 6sp: C5 clearance confirm please?
Gutruk
50
Rockhampton Australia
G'gay,
I have some confusion between atsg manual and Allison manual for actual clearance. Atsg 090 to 110 , info from here somewhere says Allison calls equal 070 to 085. Comments , input ? Thanks
About to try 3rd rebuild .....
Evan@InglewoodTrans
yerp
3,118
65
Western MA
You could be anywhere from .080 -.110 and be good to go. You'd be surprised the clearances in some stock untouched transmissions that work just fine.
15,681
I like .070/.080. Just make sure your gasket is installed when you take your measurement. I have seen them work fine at .125.
Gutruk
50
Mike, when you say air check. Do you mean air check the clutches at ports into the housing ? IE: to ensure the clutch is engaging and releasing and not leaking etc
Thanks
15,681
Thanks
Correct.
Squirt atf in the passage and fill it up. Then cut the air pressure down to 30/40 psi max. If there is a leak you will see it.
