C1/C2 clutch Drum
diesel-max
Haisley Never heard of her
Oct 20, 2011
172
IN
After completely trashing my PI converter drag racing at Scheid this year and having it replaced under warranty with a higher stall and race stator converter I drove on the street for a couple days before I had issues... C1 were welded and stuck tighter then crap and C2's burnt.... my question is in the C2 drum where the steels ride is beat to hell... is this normal or should it be replaced? it was a PPE stage 4 kit in it...any suggestions on what else i should put in my trans besides shafts? Im going to put new clutches and steels all the way through but not sure on what ones I should go with yet? I plan on installing mike L's line press spring along with everything already in it from PPE... is there anything else you guys suggest I should modify or install while its out again?
C1s warped and ate most the friction material off on one side and were welded tight took pry bars to get them out
diesel-max
Oct 20, 2011
172
IN
They wouldnt send me anything else back. Im going bigger this year also.
15,681
The picture is not that clear but it doesn't look good. I would replace the drum and use OEM steels in the C2 because they are softer metal and will not gouge the drum. The drum is made out of very soft steel to save on tooling. Hard steel material will cut the drum like a hot knife in butter.
diesel-max
Oct 20, 2011
172
IN
Thanks mike! will the Stock steels hold up to the abuse of drag racing and such?
custom8726
2,784
Upstate N.Y
Kinda wish I knew this^^3 weeks ago when I refreshed my clutches :eek: Anyways guess well see how long she holds up this go round;)
diesel-max
Oct 20, 2011
172
IN
With the ppe kit already installed from before it has the shim they sent for the main press.... does your spring up the pressure more or should I just leave it as it is?
jkholder09
Jan 8, 2012
1,188
Maryland
mike l is a vendor here and i am sure he has drums
I heard somewhere suncoast my have some thinner type oem material steels and If they are available Mike would have them.
diesel-max
Oct 20, 2011
172
IN
I was going to pm you and check if you still had some bustedknuckles still might do so if i end up changing it.
jkholder09
Jan 8, 2012
1,188
Maryland
It would be nice if someone had a c2 steel with every other tooth missing, that way we could index them and get 2 builds on a drum
any thoughts on this?
jkholder09
Jan 8, 2012
1,188
Maryland
Well mike l I suppose if you do it right the first time they will never come apart again for 95% of them.
I was kinda thinking in the 900 to 1000 rwhp range where you gotta freshen up friction every now and then.
