Bursting is the condition when the engine coughs, power goes to zero, then power starts up again. It is accompanied by WHITE smoke, which is unburned diesel fuel that has been atomized.
When it was first seen, it was thought to be fuel starvation, but what actually causes it is not enough heat to ignite the fuel that is being injected.
The way to stop it, is to:
- Keep the air hotter.
- Cold engine cools down the air.
- Lowering the compression reduces temp of air.
- Preheaters and glowplugs can heat up the air.
- Shoot the fuel in later.
Too much timing is the #1 culprit. Air is hottest at TDC (or shortly after) and that's the best time to shoot in fuel if bursting. But you need timing to make power, so it's a trade-off. A DSP2 tune for low compression engines can work wonders, or a program that aggressively pulls timing when water temp is low. The problem with the second option, is that if you are called to lanes, you might not have the water hot enough to make big power. - Shoot the fuel in slower.
What would be really good with a Common Rail, is to change the size of the injectors while the engine is running. But we can't. So we reduce the pressure instead. This brings the fuel in slower, since you can "put out the fire" by spraying the fuel in too fast. As fuel atomizes, it cools the air. So less fuel cools the air less.
