Can these be bought or is the only way to get them is by buying a Bullyeye turbo? I am thinking about putting a Billet wheel in my S366, but don't want to spend 400 dollars on a shiny wheel that don't do much more then a BW cast wheel. Any thoughts.
I was thinking of getting ahold of him. Is there any other good options out there?Tct is well worth it but come from bullseye on assembled chargers only. Get a hold of broviak. He may be able to squeak one in.
I bought 2 tct wheels for a lly from broviak last February
If figure that it would be more then 400, but you get what you pay for. I am hoping to improve the rod bending capabilities
Fixed it for ya
How much increase do you see with the normal billet wheel? How much is any fuel? Is the fault in the Shaft not being big enough or weight/force unbalance?I do NOT recommend BMW or TCT on the S300 carts! The compressor wheel is stronger than the turbine so if you throw any fuel at it what so ever you will snap the shaft! The billet 366 wheel is $399. That's the wheel I use in the S366's.:thumb:
Well, I've seen up to 850hp on the billet 366 but it was with a custom exhaust housing. The shaft is not strong enough for the amount of load that the wheel puts on it.
