Congrats! :hug:
You should do routine compression testing, and when it falls 10% tear down right away.
I had run 754rwhp with a stock engine, but not for long. First symptom was white smoke on startup, then came a rough idle. Compression test showed all cylinders low, IIRC, the lowest being 250psi. All rods were bent, but otherwise good, so all I had to do was get new rods for it, and could reuse the pistons without even boring.
Going to do a compression test today. Truck is parked for the winter and it will get built in the off season
Thanks for the comliments
