Ok so I am having problems with my 03.
I will try to make this short and sweet but most likely not... I drag raced the night before on the last pass I noticed a slightly different shift. It didn't throw me into limp mode and didn't shift really hard just not as smooth. I'm not sure if that is related somehow.
The next morning I drove around without problems until I parked, my wife went out and started it and when I got in the seat I noticed my abs, brake light and service brake system. My speedo would not work the indicator was gone and it feels like I only have p r and 3rd.
The first set of codes were
Unk u 1000
Abs c0035
Abs c0055
Pcm u2106
Tccm (/ab u1000
I cleared them and drove literally 4 houses down with no problems than it threw me back into 3rd with the following codes
Tcm p0562
Abs c0035
Abs c0055
I had a bad battery which I swapped out for new ones hoping that was my low voltage code with no luck.
Codes
Unk u1000
Abs c0055
Abs c0035
Pcm u2106
Tccm (/ab u1000
I have looked over harnesses to the transmission looking for hot spots in the shield with no luck, I also checked some fuses I thought may be linked to the trans.
Will the sensors in the hubs do this? I'm not quite sure what else to look for
Unk u 1000
Abs c0035
Abs c0055
Pcm u2106
Tccm (/ab u1000
Tcm p0562
Abs c0035
Abs c0055
Codes
Unk u1000
Abs c0055
Abs c0035
Pcm u2106
Tccm (/ab u1000
