Built Motor Questions??
DirtyMax97
Jul 2, 2012
11
I got this quote from my local shop for a motor build. I was wondering if this was a good price for all this stuff? ADD Anything you think would help this build out. Also HP rating for when its all done!
R&R rods 2,700.00
PPE race pistons 2,000.00
Main studs 375.00
Head studs 575.00
Hamilton push rods/ Valve springs 1,000.00
Hamilton cam shaft 800.00
Head gaskets set of "2" 250.00
Gasket set 600.00
Main and rod bearings 550.00
Oil pump 250.00
100% over Exergy injectors 2,100.00
Dual cp3 pump kit 2,100.00
s400 turbo kit 2,350.00
Rear true trac with bearings 1,000.00
Hard parts TOTAL $16,650.00
machine shop $1,200.00
tear down and build $1,500.00
FINAL TOTAL $19,350.00
moparkxracer
2,309
33
Out and about
picture.php
Good call on fingers pistons.. Missed that.
5,818
what ever YOU want. we cant tell you what you will and wont like when we dont a know a thing about you ;). time for you to do some research on what would suit you
DirtyMax97
Jul 2, 2012
11
I was think maybe a billet wheel Billet S363 with .83 ar t4 divided with a big Billet S468 over the top of the smaller turbo. I think that should be enough air
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
S468 is not a good turbo to put as the atmospheric charger in a twin setup. Smallest I would ever go would be an s480.
DirtyMax97
Jul 2, 2012
11
Do you think that set of twins I just mentioned would be enough to support the truck or would I have to go bigger
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
No I don't think so. You would want a bigger exhaust turbine and housing for twins, the the compressor housing wouldn't move enough for it to be compounded. As said before an S480 or S483 with an 96mm wheel and 1.32 ar housing would be recommend for the low pressure turbo for your S363 or S366.
DirtyMax97
Jul 2, 2012
11
I was looking on danvilles website and found this tubro
Batmo 88mm S458 96mm turbine T4 1.25 a/r. I think I might run this as the big charger!
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
Would work, just tell Mark to put the normal T6 housing on it or you will have to get custom piping to work with the T4 foot. This turbo started out as an S400 and they put the S500 turbine wheel in.
