No changes necessary. All '04 Alli's had the G solenoid. It is a direct fit.
Damn, learn something new everyday.
Whats the purpose of the G-solenoid? With all the other hard parts being the same in the in the 5spd, is there a benefit?
You cannot use a non G valve body in the later ones because it will set a code and the engine will run ruff.
YesCan't you swap in a LB7 TCM or flash in a LB7 TCM OS into your TCM and do away with it?
