BT Diesel and Fleece tap shifter users
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
Wherever I am working
Anybody out there using either of these...especially in the 01-02 models?
Pros and con's of whatever brand you are using.
Personally, I like Ben's electronics, but he lacks on customer service and response time. Fleece shifter seems a little more user friendly. Help me make a decision.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
I would love to get one to, only down side i have heard is you have to update to a newer TCM tune to get the tap shifter to work and i am not willing to give up that up quite yet.
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
What's the matter with getting the new tune? I think it's just an update on the OD/4th gear lock.
That's the way I understand it anyway.
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
OK...I know that some guys like the 01 and earlierr 02 TCM because they shift better.
However, I think the update is just for the OD lockout, isn't it?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have an 05 truck, an 01 trans, an 03 TCM tune, a DHD lock up box and a BD tapshifter. I have had good luck with the 03 OS and it solved my no G solenoid issues with the older trans and still allows OD lockout.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
I have fleece on my 04.5 lly i like it. I use it more for stopping and descending on hills. I havent used it towing. It shifts a little slow so if you going to use it like a manual its not going to do it. The fleece is nice and put together well. Installs easy in 45 min or less. You do have an extra loose pin for yours (01-03) but it is easy to install. The handle takes a little getting used to. The ergonomics of it is a little different then stock.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Just buy a tapshifter for an 01-02 truck, run the latest revision of the 01 TCM, and your good to go. Still have all the things you like about the older TCM O.S.
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
That's what I was thinking...thanks for the clarification!
