I got two glow plugs that snapped off in head any one have any tricks to gettin them out or if I just leave them and be minus two plugs will it make a difference???
Well took four hours but I got both out. First I drilled and tapped 1/4-20 down past the large threads. Then I drilled large to remove the large threads and tapped the remaining left over threads out. If u drill large just past the threads it will break off the bottom of the glow plug. I left the bottom in till I was done to keep the shavings out. Then I grabbed a 1/4-20 bolt and threaded it into the bottom piece that I tapped earlier and pulled out the plug.
