I had a broken exhaust manifold bolt which I guess is a common issue, so I welded a nut on the end and snapped the bolt at the head. I then drilled it for an easy out and then snapped off the easy out.. After using a Dremel to grind down the easy out I now have a fairly large diameter hole in this bolt. I'm weary of using another (bigger) easy out at this point.. Heads are aluminum and the threads aren't in too bad of shape at the edge of this bolt (Dremel got away from me). Looking for advice before I go for it with the other easy out.
