Where can you find the most recent Ohio rules?
PERFORMANCE TRUCK & TRACTOR PULLING SERIES
740-819-6200
740-468-9045 FAX
RULES FOR 2008
8000LB. “PRO STREET” 4X4
1. TRUCKS COMPETING IN THIS CLASS MUST RUN TRANSMISSIONS, TRANSFERCASES, FRONT ENDS AND REAR ENDS THAT CAME FACTORY IN A 1 TON OR LESS PICKUP. HOWEVER THE INTERNAL DRIVETRAIN PARTS CAN BE UP GRADED AND MODIFIED.
2. ENGINES MUST BE OEM AND AVAILABLE IN 1 TON OR LESS PICKUPS. NO AFTERMARKET HEADS OR BLOCKS PERMITTED.
3. NO SIGMA INJECTOR PUMPS PERMITTED.
4. SINGLE CHARGERS ARE LIMITED TO A 3.0" INDUCER BORE. THIS WILL BE TECHED USIN A 3.05" PLUG.
5. LIMITED TWIN CHARGER SET UPS ARE PERMITTED AS LONG AS THEY FIT THESE RULES. TOP CHARGER MUST BE A DIRECT BOLT ON AND THE BOTTOM CHARGER MUST HAVE A 3" OR SMALLER INDUCER BORE AND WHEEL SIZE. NO RESTRICTORS OF ANY KIND MAYBE USED TO PERMIT A LARGER TURBO TO PASS INSPECTION. A 3.05" PLUG WILL BE USED TO TECH THESE TRUCKS.
6. NO NITROUS, OR PROPANE. ALL TANKS AND LINES MUST BE REMOVED FROM TRUCKS BEFORE COMPETING.
7. FRONT WEIGHTS AND BRACKETS MAY NOT EXCEED MORE THAN 60" FROM CENTER OF FRONT AXLE.
8. REAR SUSP. BLOCKS AND TRACTION BARS ARE PERMITTED.
9. PULLING TYPE HITCHES ARE PERMITTED, HOOK POINT ATLEAST 36" BEHIND THE CENTER OF REAR AXLE.
10. ANY D.O.T. APPROVED TIRE PERMITTED. NO CUTTING OR SHARPENING OF TIRES PERMITTED.
11. SAFTEY REQUIREMENTS. MUST HAVE DRIVE SHAFT LOOPS AND U-JOINT SHIELDS ON FRONT AND REAR SHAFTS. BLOWPROOF BELLHOUSINGS, OR BLANKETS OR BELLHOUSING SHIELDS REQUIRED. AIR OR FUEL SHUT OFF KILL SWITCHES REQUIRED.
12. SMOKE MUST EXIT STRAIGHT UP. TURN UPS REQUIRED ON TAIL PIPES.
they dont want open driven line for next year because the ones pulling in the class dont want it:rofl:
