This past weekend while out of town at the family's Camp, I went for a ride Saturday afternoon, and truck wouldn't shift out of 1st gear and I had some codes and service brake system message coming up.
V2 said P0700, P0722, C0035 (front wheel speed sensor) and C0055 (rear wheel speed sensor).
Crawling underneath to check the VSS on the back of the T case, I was suprised to see the sensor wire was broke between the 2 connectors, I unclipped them, we pulled out to splice back together (so I could get it home, as I was 4 hours away) and when I went to put it back in, the connector ( that I believe either goes to the VSS for the front shaft or to the tranny) was also snapped, so we had to remove some loom to find out where it was broken, and spliced that together temporarily. It worked, the TCM codes went away, and truck shifts just like it's supposed to. However, immediately upon start up, I still get the C0035 and C0055 codes, they clear, and don't come back until next start up. Brakes seem to work fine.
I stopped by a local Chevy garage today, they told me $1300 for a new engine harness that would include everything from engine back, I declined. We are going to solder all connections and re-loom and and re fasten lines back in place.
I think something may have got caught in there or something, or perhaps what holds the loom away from the front drive shaft broke or came loose and it (wires) became entangled around front shaft.
Any thoughts on the ABS codes? Anyone have a harness they want to sell the VSS connector wires from?
Thanks.
Thanks.
