Broke up pipe bolts
firechaser1141
Jan 31, 2017
14
I recently purchased a set of up pipes and manifolds so I was trying to unbolt the up pipes and broke some bolts off in the stock manifolds. So what kind of bolt can I purchase at lowes or somewhere that will work as good and dose it need to be a certain grade or type of bolt?
Oct 16, 2008
948
12
Idaho
I'd just look for a high grade flanged bolt if buying factory bolts isn't an option. I wouldn't overthink it too much.
Awenta
4,090
CT
Exactly. I just replace things with grade 8. Anti seize is your friend too
cntry125
Gearhead
Sep 7, 2008
103
Wisconsin
High temp nickel antisieze is your friend. It just helps that much more in my opinion.
2007LBZ
Piston Melter
Feb 18, 2017
17
TN
I bought some ARP chromoly bolts for my up pipes. Instead of buying from a Duramax specific vendor and paying $15-20 for 3 bolts, you can use part # 672-1003 and get 5 bolts cheaper.
aashton1206
172
Did you break manifold bolts or just up pipe bolts
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, custom tuning on v2 for daily driver, 33x12.5 nitro at on 20 inch American steal wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust w/ 6 inch tip, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, FEd Y Bridge.
