Brakes
duramax215
Team Jacoby
Dec 17, 2008
456
Waubeka, Wi
well i went to my local auto zone and i need rotors and pads all the way around and when it came to the rear rotors they asked if my truck had a 2in body lift?? i have a 2004 lly crew cab short box 4x4 the difference between the 2 was how wide they were. so what ones do i get the one with the body lift (wider) or no body lift (less wide) thanks
Corey
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
:confused: Maybe I am dumb but... WTF does a body lift have to do with the Brake rotors, or Pads? Was this the typical 15 year old pock faced teen workin behind the counter?
duramax215
Team Jacoby
Dec 17, 2008
456
Waubeka, Wi
thats what i was thinking!!!! and no he was older!!! i was thinking it also had to do with the fact that i have a half year and parts could be different from a lb7 or a lly :confused:
duramax215
Team Jacoby
Dec 17, 2008
456
Waubeka, Wi
haha right!!! but i took a look at them tonight and guess what i think i have the one with the 2 in. body lift because the ones i bought aren't as wide as the other ones!!!:confused:
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
Yeah, I ran into the same thing when I got rotors from Advance. I got the wrong ones and then took them back... asked the guy at the counter the difference...and he said the correct ones were for a truck with 2" body lift. :confused: I guess it has to do with the 11.5" AAM axle used behind the Dmax.
durallymax
Apr 26, 2008
2,756
Under The Hood
There is a difference its the hub bore size. its not much only a few hundreths of an inch but its enough to make a difference Why i dont know but there is. Hes not dumb.
now i cant remember which ones i got for our 02. but i just took one of the stock ones in and they matched it up.
Whitetail Addict
May 8, 2008
2,350
Sidenote - IMO its better to spend the extra money and use the GM brake pads. I got the most expensive ones from Advance for the rear of mine and they squeel...not bad but annoying none the less.
When I did the front I used GM brake pads and they are silent.
13,712
773
What a stupid way of entering that information into their computer. There is no 2" body lift on our trucks. The frames are taller or something on the 2500HD and 3500 (as can be seen in the taller bumper cap on the Chevy and the filler panel on the GMC grille), but that's it.
