I am thinking of upgrading the stock brake pads and rotors. Any one got advance on which aftermarket company has the most bang for the buck.Also will change the brake fluid too.
Got mine from
http://brakeperformance.com/
I have been very happy with these.
I got the premium dimpled and slotted rotors with the upgraded pads.
Since it's similar I figured I might as well ask, has anyone just swapped stock lines for the braided and could you tell any difference? I was considering flushing the system and figured no better time to change the lines but only of it is worth it
I was looking at the russell ss braid lines and was gonna put them on too since i was doing the brake fluid. I was thinking about just doing the front fbrakes and then later on doing the back brakes. But might as well do it all at once. I looked at the brake performance site and thats what im gonna go with.Also when you bleed the system do u still have some one pump the brakes till they get hard and hold it, then bleed the caliper? Thanks guys
I was looking at the russell ss braid lines and was gonna put them on too since i was doing the brake fluid. I was thinking about just doing the front fbrakes and then later on doing the back brakes. But might as well do it all at once. I looked at the brake performance site and thats what im gonna go with.Also when you bleed the system do u still have some one pump the brakes till they get hard and hold it, then bleed the caliber? Thanks guys
