Brake Torque Mgmt
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Before my slicks i was playing with using the max fuel per vss table , it worked quite well once it was dialed in . Something simaler to what you see here , brake torque will do good to limmit launching but once you are going it will be full power , if you use thew vss it can be as gradual or explosive as you want it to be .
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I changed my tunning to get rid of the brake torque managment. If I went over 35% throttle on the line it would kick in. I then could put it to the floor and the truck would come out like a fat man off the couch. Now since I changed it I can come out hard and hard enough it will spin to the point it blows through first gear and makes my butt pucker up and let out of it so I don't break anything:eek:.
jpowel29
780
Bentonville, Arkansas
How/what did you change on your LBZ?
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Go to Torque limits and then to the parameters section. These are the numbers I put in. I can't/don't know how to just take the image of that screen and post it so this is the best I can do and numbers are in order of how they list from top to bottom. Hope this helps.
100.000000
100.000000
0.000000
1300.000000
1300.000000
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
If what I posted dosen't make since i can send you my stock tune with this table set up this way so you can see what I did if you want.
13,735
804
B1123 will do the same thing as what Trent is doing. As far as the brake torque tables go, what exactly are you trying to do? I haven't played with it on my truck, but I have on my dad's. It's really nice the way I have it set right now. Full throttle with my foot on the brake, the engine will stay right at 2100 RPM, and as soon as I come off the brakes, it takes off hard. You can adjust the torque value up or down to raise or lower your launch RPM.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
No - I went right to the parameters and keyed those in. I'm going to load this tune and see how it drives out tonight. Most of the streets should be cleared out.
Good luck today at the smoke out deal, i really wanted to go but wasnt ready.
