Bose amp
Firefightkev
May 30, 2014
111
Central Florida
I have search high and low and can not find a diagram for the colors on the line out of the Bose amp under the center console. It seems most run new wires or keep the amp then add rca cables for after market subs. I would like to use the exsisting wires to run the door speakers and a piller tweeters from a new head deck. The truck is a 2007 classic body style 4 door.
Firefightkev
May 30, 2014
111
Central Florida
Ok so i found a page that i will put a link too that helped me. It does not have any pics but come to find out GM runs the Bose system through standardized wires. The wires coming off the amp reconnects to the standard factory radio wires that any truck would have they are behind the a.c. controls. The stock harness mounts on the right side behind the ac controller. You unplug it and it has all the speaker wires power ect. The only thing i dont have is the tweeters in the A piller. I put a box on for door chime and used the stock main plug. I didn't run new wires or anything. Only issue is the tweeters not working.
http://www.silveradoss.com/forums/topic/62912-bose-bypass/
