I'm pretty set on doing a Borg s366 the specs are as follows.
Compressor: 66 mm inducer / 91.4mm exducer, with exclusive Extended Tip Technology.
Turbine: 80 mm inducer / 73 mm exducer. Cast in Inconel 713 for high-temperature operation.
Compressor: Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
Turbine: .91 A/R Twin Scroll, with 'T4-style', divided entry, and 4.21" v-band discharge.
I plan on running that turbo with a billet wheel from either bullseye power or engineered diesel along with a race cover.
Then I came across a pretty good deal on a turbonetics gtk-1000. Specs are as follows.
Compressor is a 76mm
Turbine is a F-1 Trim 68MM
Compressor inlet is 4" and discharge is 2.5"
Turbine housing is a Ceramic Coated T-4 open design with a .96 A/R and 4" discharge
It is a ceramic ball bearing turbo.
I haven't really compared map yet. Just curious if anyone has ran the gtk possibly or have any insight. I plan to be about 600-700 hp daily driver/weekend warrior type truck. So need something that can support that power level but spool really fast. With the turbonetics I'm sure I'd have to wastegate it where I could probably get by with the 366 without. Let me know what you guys think. Thanks
