LB7: Boost with PPE Boost Valve
KEVINL
1,431
Phoenix, AZ
What are you guys seeing for maximum boost I am running a 2900usec pulsewidth smokes like a frieght train boost seems to hit 28 and then goes back down to 25
I was getting 2.0 plus bar before with my old gauge that was electric I am wondering what the deal is
Also it hits 25 with the stock tune.
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
:D
A brass "T" in the line going to the waste gate. The T then has a hole drilled in it to bleed some of the boost signal delaying gate opening. I still have it around here some where...yours if you want it.
maine04max
Dec 11, 2008
1,009
with robs tune im getting 30 - 31 .... stock tune only 21 maybe and edge i was seeing 24 max
KEVINL
1,431
Phoenix, AZ
I might give it a try Brandon
With the rain and the cooler temps It seemed to help the turbo alot I could actually hear it I saw a momentary 30 psi spike under part throttle but it drops to 25 at wot still seems to be plenty of smoke
I have some Juice Grips:happy2:
:badidea:
1,842
Have hit 32-33 at shift points, then it drops back to 27-28 as rpm increases between shifts.
