well for one, MAF isnt going to tell you boost, MAP will.
Second, you can log PISG via efi live and not just PSIA like you are probably seeing, its just maxed at 22-24psi.
if you want more, search on here for the higher pressure honeywell sensor that can be wired in. you will need to rescale some tables to make it read correctly
