Boost Sleeve Problem!
bmos37
Nov 23, 2008
176
Gainesville,FL.
I am having a problem with a boost boot that keeps blowing off the turbo on the drivers side post turbo, This problem started a few days ago when i mash the pedal all out and i have put 3 different sleeves on that worked prior & now even the sleeve that i got from guy at socal diesel seperates under full throttle. Could anyone put me on the right track to getting this fixed?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
clean the surfaces with a degreaser/ wax remover or even mineral spirits /acetone , only time i blow boots off is if they get a bit of oil on them , if clean.............. mine never blow off even at 50 psi , are you using a good quality clamp ?
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
I double clamped mine on. Also make sure the piping is isnt dented, one of the times mine blew off it dented the boost tube.
wilsonck
May 8, 2008
206
Calgary, Ab
i remember someone saying that after cleaning, they would use hair spray on the tube, then slip on the boost boot... could try that
Philtopgun
Nice n Easy
May 5, 2007
710
45
Edmond,OK-still a Texan
Ugh, never had this problem til now for some reason. I've had the sleeve on for couple yrs with no prob. Now SD sleeve pops at wot... Did windex and hair spray without luck... What's tha dealio??!!!
