Boost Leak
Jake707
76
I bought a boost tester just to have and popped it in to see and found out I have a boost leak. Here’s a video in real time so you can see. I don’t know how bad this is but 20 psi leaks out to 0 in about a minute and a half.
I was able to trace the sound to I think right at the intake. It was coming from under the plenum with the wire harness running across the top. Would that be the o rings on the y piece? How bad of a leak is this and will it cause issues if not fixed right away?
Source: https://youtu.be/XRmq07mz7xI
Bdsankey
4,156
1,264
Larsen, Wisconsin
I don't think anyone can exactly where your leak is coming from. If it's coming from the y-brige area, take soapy water and spray it all over in that area and follow the bubbles.
