Hey guys has anyone ever had a boost leak at the map sensor. I boost leak tested my truck and I get a hissing on the right side of the motor slightly to the right of the y bridge under the wiring harness I stuck my hand in the vicinity and when I put it around the map sensor I can feel the air escaping in that area. Is it possible the seal on it went bad? I inspected around the y bridge and I don't think it's leaking there. In the past I did an HSP y bridge on the truck and when I tested it back then the system was sealed. Thank you all
