Boost issue!!!
slipclutchms
427
Which PID are you looking at? Probably are looking at barometric pressure + boost. That is the only thing that makes sense.
Duramax52513
Jun 23, 2013
99
i hooked the truck up to scanner, i don't have any gauges in the truck yet. basically what happened was i raced another truck one day right after i installed the intake and took the muffler out. i blew a bunch of black smoke and everything was fine. ever since that day i have noticed a lag, and she seems a lot slower then she used to be. so i took the truck to a buddies shop and hooked it up to a scanner and the only things that seemed off was the boost pressure reading 15psi at idle.
jc1843
Sep 27, 2009
228
86
So Calf
The turbo will NEVER make 15lbs boost pressure at idle. As stated above, you are reading atmospheric pressure-- sea level is 14.7 lbs.
