Boost Guage
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
Where is the best place to mount the vaccum tube for boost guage under the hood? I already have it mounted in one of the silicone boots on the intercooler tube, but in hindsight that does not seem like it was the best idea. If possible could a pic be posted? I am just thinking that if I am able to create more than the 20psi it makes now, I will probably blow it out.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
splice into the waste gate line
I personally don't recommend this method as it will give a false reading rather than actual boost pressure that your engine is receiving. It is easier, yes but it will read higher than what your engine sees. I would tap the signal line post intercooler as close to the engine as reasonably possible.
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
i don't do it either but the way i do do it isn't something most people can whip up in their drive.
13,765
834
You can delete the intake air heater and put it in the plug you use to block it off. I've seen a link to one that is already drilled and tapped.
