I'm in the middle of the build and looking for advise on using the BD flexplate and a built trans by Mike L. During install, should I use RED or BLUE loctite? I've seen a bit of conflicting info. Yes, red should use heat to remove (I didn't use heat unbolting the converter taking out my trans installed by Mike) so either Mike didn't use red or I got lucky. I didn't see any thread damage to note. Thinking of that, I'm guessing blue but now not sure.
Next - should I get new bolts or re-use? I don't think they are TTY and the OEM vs BD flexplate thickness isn't much difference. I haven't measured but the part is supposed to be directly interchangeable.
Finally, when re-installing the engine, what has been your best process to line up the trans/TQ/flexplate. Do I push the TQ converter back, bolt up the bell housing, then slide the TQ conv FWD to touch the flexplate and then bolt up?
