Help: Bolt in center of leaf springs
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Any tricks to tighten this bolt up. It just spins when I try to tighten it up.
i usually just use a pair of vice grips on the round part underneath the leaf pack . the leaf pack need to be raised from the perch though to get to it .
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
any ideas on how to do it with the spring still bolted to axle?
I pulled my overload springs and I thought I had those 2 bolt tight but after I sucked down the u-bolts there both a little loose....
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Same deal I did... tried to pull my overload and the bolt was too loose and wasnt threaded enough to tighten up so I need to get some shorter ones or something so I can pull the overload and it still be tight.
TrentNell
Jul 7, 2008
7,543
slc tuah
i had to take a die and thread mine further down . only way i can think is try an impact gun , or see if somethink like some needle nose vise grips could fit through the perch .
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
iirc you will need to tap the bolt a little deeper. i think i had to do the same thing when i pulled my overloads.
are you running drop shackles?
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
2" drop shackles and now no overload. I cut some more threads in it. I thought about just hitting the bottom of it with a little tack weld to the spring seat so I can get the impact on it. Theres room underneath the spring seat....
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
only reason i ask is b/c when i pulled my overload and ran drop shackles i had a ton of wheel hop. like even going around the corner it would hop.
