My LLY has a lot of blowby. With the PCV re-routed to atmosphere, if I have the oil cap off, I get quite a bit of it out the oil cap AND from the PCV hose, and have a lot of oil on my frame rail by the hose, and small puddles of oil end up under the hose periodically. My guess is it's rings, since it runs fine and balance rates are normal and if it was a hole or crack in a piston, it would probably run rough.
Would it be possible to replace the rings without honing the bores, or is honing absolutely required? I don't expect much more than 50k to be put on the block. If replacing the rings without honing is nothing but trouble, then I'll just leave it as is and not worry about it until my shortblock is built (which will be a while yet).
