Ok....
I just recieved my isspro 60psi gauge that I had planned on using for a drive pressure gauge.
Interesting timing... I was driving my truck yesterday and started hearing a faint air sound.. sounded like a boost leak kind of. Noticed lower boost etc.
I have been meaning to pressure check my truck so I built a pressure checker and put it in the system just after my turbo. To my HUGE surprise my system is as tight as a duck's ass.
So I decided to go after my drive pressure gauge which I had planned on installing in the blocker plate I made when I deleted my EGR system.
And bam... there was the issue I was hearing before. I had actually braced my plate onto the head and the brace broke!! It wasn't small either. Of course once it broke, that let the bellows on the egr riser vibrate around and to eventually blow out
Fix: I cut that motherf*cker off and machined a plug and welded it in the riser to eliminate the bellows completely. I also drilled and tapped the plug for my drive pressure gauge. Two birds with one stone. So far so good...
Wasn't fun working in that area though whew, glad thats over with!!!!
Drive pressure gauge results:
Holy crap... I lowered my vane position after seeing the results!!! At high rpm I was seeing nearly 60psi (with only 25psi of boost)
This will be helpful with tuning!
Pic below,
Thanks for reading!
Pic below,
Thanks for reading!
