Info is also captured here: K&D Service Rotating Sales
I will be updating this as new sales come online!
Exergy: 10% off 11/29-12/2 on all items with the exclusion of billet fuel rails, Bosch Motorsport ECUs/components, and LML CP4.2 pumps.
Dynomite Diesel: 15% off all products with the exclusion of "Super Mental" line (custom sizing). This means the sizes below ARE included.
1) 01-10 Duramax, 150% and down
2) 11-16 Duramax, 45% and down
3) 17+ Duramax, 25% and down
4) 03-07 5.9L Cummins, 150% and down
5) 07.5-21 6.7L Cummins, 100% and down
6) 22+ 6.7L Cummins, stock
7) 08-10 6.4L Powerstroke, 100% and down
8) 11-14 6.7L Powerstroke, 45% and down
9) 15-19 6.7L Powerstroke, 45% and down
10) 22+ 6.7L Powerstroke, stock
FASS: Fass will be running a 10% off MAP sale 11/29-12/3.
JZ Mfg: I will be personally running a sale on these for Black Friday. I will be doing $100 off all turbos they produce AND still offering free shipping (including return shipping on reman VGTs). All VGTs come with gasket kits and remote oil feed lines.
Fleece: 15% off 11/29-12/13. The only exclusions will be their long blocks.
Forced Inductions: Various sales from 11/11/24-01/03/2025
1) $200 of FIS GTR (Garrett based) and S400s (includes BB GTR S400s)
2) $100 off S300 & BB S300
3) $75 off TDI billet S400
4) $25 off TDI billet S300
5) $50 off turbine blankets (T4, T6, & GT55)
K&D Service:
We are running a sale on in-house-built transmissions for Black Friday this year for any build booked/scheduled during the entire month of November.
We will be supplying an aftermarket Goerend flexplate and OEM bolt set with every transmission booked/sold until the end of 2024. I have a few cores here to build 01-16 units. I sadly do not have any 17-19 cores at this time but can build them if local to us.
Our builds are $5750 cash-and-carry (with a core) for a 750hp built unit and includes the below items:
1) Goerend billet stator billet cover converter of your choice (R, J, & AR and extreme clutch upgrade available for an extra cost)
2) New Allison speed sensor(s), pressure switch/manifold, wiring harness, and pump
3) New C1 (16 friction)
4) New C2 w/stock steels (7 friction)
5) New C3 w/kolene steels and LML pistons/return spring assemblies (6 friction)
6) New C4 w/kolene steels and LML pistons/return spring assemblies (6 friction)
7) Goerend deep pan w/new filters and internal filter lock
8) All new bearings/bushings/gaskets/seals
9) Hydraulic modifications for increased holding capability, shift quality/speed improvements, and additional circuit drilled for increased cooling
10) Case painted gloss black
11) New NSBU
12) New cooler fittings
13) K&D PTO covers
Above ~750hp we start adding billet and can work with a customer at that point.
All comp builds will come with the choice of billet flexplate OR Goerend/DHD style and aftermarket transmission lines.
Comp builds are $8995 cash-and-carry (with a core) and include all the items in our 750hp build PLUS:
1) C3 oiling lines
2) Billet input shaft
3) Billet C2 hub
4) Billet P2 planet
5) Billet output shaft
K&D Service:
11) New NSBU
13) K&D PTO covers
1) C3 oiling lines
3) Billet C2 hub
4) Billet P2 planet
