At what point do you think billet caps and or a stud girdle is needed? I am going to be machining a LML block for a customer. Going to be a hot street truck I believe. Proby don't need them but wondering what others think.
So Is that machining all the other mains to be like the #5 main with the sleeve over the bolt hole or is it an actual dowel pin?Dowelled stock is about all you need. Beyond that, you need a billet block since a lbz/lmm/lml is only going to get you 1500-1700 reliably.
