Biggest Tire on 05 2500
DopdBrd
Feb 18, 2010
3
So this truck I picked up needs some tires. I don't know if I will do wheels quite yet so for now lets just talk tires. It has the factory 17 inch wheels and I want to put some 33's on it. If I just cranked down the torsion bars could I fit something like a 285/70R17 on it?
paint94979
Beer Nazi
Sep 18, 2006
11,715
factory wheels are 16's... unless they are the stock wheels on the LMM's they are 17's... I have run 285/75/16 BFG AT KO's on AR wheels and they rub like a mofo
farky
DIRT POOR FARM BOY
Jan 14, 2010
75
Leesburg, Ohio
i ran 295/70/17 toyo mt's on h2's on my 06. had about 4 turns on the t-bars and never heard them rub once. very good fit so i'm sure you will be fine with that size
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
i m runnin sme aftermarket wheels 16x7 on 265 75 16 bridgestones. the wheels stick out about 1 inch more than the stockers did. i trimmed my fenders because they rubbed bad and still rub when i drop my torsion bars....i thin k offset has more to do than the tire size
you should clear a 33" tire with ou to much trimming and cranking the bars
Sam
Mar 31, 2010
Midland, TX
It all depends on your offset, stock is ~20mm POSITIVE.
If you go with a negative offset, you're putting the tire out there further and with the extra leverage you're gonna run into rubbing problems w/o a lift/level if you go with a tire that's got any size to it at all.
here. compare.
http://www.rimsntires.com/specs.jsp
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
315/70/17's fit nicely on my truck with no lift
i can also drop my torsion bars and go pulling just cant turn the wheel too far or i will rip off my fender flares..
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
i ran 315/75/16's for a while and somehow got away with it. had bars cranked to the max and trimmed a decent amount but they only rubbed at full lock
however i wouldnt recommend that
MFDinosaur
May 20, 2009
14
Northeast Florida
If you're looking to lower the front a bit, you can run a 285/70 17 (32.8 inches) on H2's with a little trimming of the valence and the bars cranked all the way down. You will also need to zip tie the e-brake cable and do a little pounding with a hammer to knock the inner fender well back a bit. A couple of zip ties on the front of the inner fender well will keep that from rubbing as well.
There may be a little more room to go bigger, but not much over 33 inches.
