Info: bigboper
KEVINL
1,431
Phoenix, AZ
I cryogenically treated my rods and they have been holding 1000hp I just pulled them out and stuck them in the freezer over night
:secret::D:spit:
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
key'd crank , don't have to , just use lock tite on reluctor and harmonic mounting, you will be simply amazed: george
Under what condition? I've seen two key ways sheared from driving two superchargers off the ole front. But, wonders never cease to amaze me. Good luck with that.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
No deal on that for sure man ! I read something about can he run them off his cigarette lighter or something 12v :spit:
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
To bad I didnt think about using loctight on my sheared camshaft dowelpin:rofl: Could have save myself so $$$$ on the motor build
9,905
149
Not sure if that would 100% work or not. Reason I might be inclined to believe it though is due to something I saw in the past.
I saw a 6000lb planetary hub being held off the ground by a 1" wide bead of silicone and nothing else. The diameter of the hub was about 4'. It was a fight with pry bars and chisels to seperate the two halves with gravity helping to seperate it.
His idea may not be as dumb as y'all think it is is all I am saying........
