Big engine fail
jc64
#131
Sep 29, 2006
308
60
Oregon
Check out this engine blow-up from Europe.
[YOUTUBE]kCsSVLZ6wCI[/YOUTUBE]
jc
slowlmm
Mar 2, 2008
2,582
46
so cal
mabey he should of used some of that chain from his steering wheel to hold his motor in better LOL
jc64
#131
Sep 29, 2006
308
60
Oregon
I would say the mechanic who works on 'European Maid' needs to sell his/her tools and move on to something less techinical.
The 1st vid I posted was from 2008. This vid is from 2009.
[YOUTUBE]bpPX8R7Jle4[/YOUTUBE]
That was interesting. I honestly didn't know they did that stuff in Europe.
Yah. They just have little tractors over there.
[YOUTUBE]FJD_9V682cc[/YOUTUBE]
[YOUTUBE]sS18PxDFAR4[/YOUTUBE]
Also check out the tractor called 'Dragon Fire.' Search it on YouTube
[YOUTUBE]s3iyOvLXxF0[/YOUTUBE]
ps. Thanks for fixing the vids for me.
jc
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
The "Dragonfire" Tractors engine is a Zvezda russian marine radial diesel converted to alcohol and spark ignition! I did some searching/reading on it and build pics, pretty amazing! Its better that they used somthing more avalible like Zvezdas than use rare engines like Pratt&Whitney 26cyl R-4360 Wasp Majors. European pullers like aircraft engines, especially V-12's and radials. Very cool but should be in plane restos! (Im a plane buff:D)
Zvezda also had a 112 cylinder monster! Its 2 of there 56cyl's joined:eek:
Featuring specs: 16 rows with 7 banks of cylinders, bore of 160 mm (6.3 in), stroke of 170 mm (6.7 in), and total displacement of 392 liters (23,931 in³). The engine produced 10,000 hp at 2,000 rpm :eek::eek::eek:
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Considering these Superstock tractor guys are pushing boost in the 150-200psi range, one stuck/malfunctioning waste gate usually leads to carnage like this. Or sometimes the stress of making 2500+ hp on a block designed to hold 120hp causes them to fail as well!
