I know I'm not the only Duramax owner who is fed up with their DPF problems but I'm looking for some advise. I own a 2011 (first mistake was buying that model year) Sierra 2500 with 89,000 miles. I've had all the typical issues with it (nox sensors, indirect fuel sensor, replaced DEF tank, etc.).
My question is does this system become more reliable with the newer model years? We pull a large 5er and it wouldn't hurt if I went up to a 3500 but I don't want to if I'm going to run into the same issues with a newer truck. The latest issue popped up less than 24 hours before we were to leave with our 5er on a 700 mile trip traveling on a Sunday. Luckily the stars aligned and I was able to get it to a dealership Saturday to fix the problem.
So far my continual problems have either been covered under warranty or as the last two issues were, under a GM extended warranty due to the ongoing problems with various parts within the DPF system.
I've looked into EFI Live and will probably do this at some point no matter what truck I end up with but I'm not looking at doing a full delete (not a fan of the black smoke and noise that comes with it).
Looking for some advice and thoughts on the newer model year Duramax exhausts systems. Thanks in advance!!
