LB7: Best Way To Leave The Line...
RobsDmax
832
Arthur, Ontario
Well hooked this weekend at a local pull and ended up top ten, which was fine by me, first second third were all 700 HP plus, I leave my truck in 4lo, in 3rd gear and tow haul on, and the truck seems to defuel hard 2-3 and drops some momentum. Any ideas?
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Eric (wisconsinhick1) is who programmed mine. Probably be a little harder on it, but shifting under heavy load is not easy on it either!
AdaMax
Nov 26, 2010
412
Caldwell , Oh
Leaving the line depends on the track . I personally build as much boost as I can then let her rip most of the time . But on a bad track sometimes you need to get the sled moving forst .
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
My DD stock fuel and air I still start in 1st and usually just hammer it off the line. It's usually pinned in 3rd gear converter locked 10-15' out. 60% of the time it works every time :rofl: I get no defuel.
