I've been noticing a different sound from my turbo since I had my new injectors put in, it almost sounds like a belt driven supercharger whine when the turbo is boosting. My first guess is I have a boost leak somewhere because my turbo doesn't hold steady boost pressure when I keep the pedal in the same spot, it will fall down to 5psi or less. So I was thinking to check of a leak I would disconnect the hose coming out of the turbo and the one going into the y bridge the put a PVC pipe cap in one end and tighten the hose clamp down on it the get another cap and put a tire valve stem in it and put in in the other end and pressurize the plumbing and see if it holds pressure or not, or am i having a different problem thats causing this issue? Any and all opinions are greatly appreciated on this subject. Thanks
