I thought maybe there was one that would hold up better to a controller cycling it on and off. I would think that it would create heat and be hard on a solenoid. BTW I'm from Iowa.
-Randy
I like the NOS ones. I have a pro race solenoid which is a 450hp solenoid and it only draws 8.6 amps. All the NX ones of similar size that I looked at draw 30 amps.
I'm just waiting for somebody to get back to me on the tranny, he was busy this weekend in Florida. I'll run it that way first to make sure all is good and then start adding nitrous. The tracks don't open for two months so I should have plenty of time to get ready. I hope
Alot of pressure to deal with I'm thinking (pulling up the plunger inside with 900-1200psi on top of it). I know the one's I use to sell needed a 15amp fuse and if you ran quite a few runs back to back, some times it would pop it and we had to install 20amp fuses. Wiring was good for 40amp though so no hot wiring.
