Odyssey, Deka, or Cat.
Odyssey model number 78-790 and 78-PC1500.Last time I looked odysee did not make a side post battery so that singles out at least 01-07 not sure about lmm being top or side.
And cat batteries are overpriced like everything else they sell
The fact of the matter is that ALL batteries are made by one of two companies. Theres only two companies in the US that manufacture car batteries....Johnson Controls, and East Penn MFG.
Everyone else just slaps their label on them.
Get a top post battery, cut the side post ends off, then I just got some ends from an audio store so they are still kinda covered and just tighten down the screw on the end of the wire. Has a couple other holes in case you want to add something also. http://www.carid.com/t-spec/4-gauge...PreYxKz_5qpyhcGZfGevh6unfVyRGabEIUBoCsmDw_wcB
The 127-0826 875 CCA cat battery performs very close to the Deka and Odyssey batteries, and for the money it whips there ass Alaska dealer pricing is at 125 bucks, pretty reasonable if you ask me. It is dual terminal so hooking up stereo bs is easy.Odyssey, Deka, or Cat.
How is 125 bucks overpriced at 875 CCA? Not many batteries have that kind of power at that price...Last time I looked odysee did not make a side post battery so that singles out at least 01-07 not sure about lmm being top or side.
All will corrode if not kept clean and sealed... I have a set of original AC delco in my truck that are corroded at the side terminals... If you keep them clean and use a battery sealer your good to go.The issue there is top post batteries are subject to corrosion, I have never in my life seen a side post battery corrode at the connection.
X2. I run the die hard platinum agm batteries. No leaking like the my old batteries. Had them for about 2/3 yrs iirc.Diehard platinum
