Best 305 50 20 tire
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Looking to put new wheels and tires on the LML. Goona go with 20x9 wheels and 305 50 20 tires. Most of the street tires I've seen in that size arent rated for the truck. Wanted to go with either Nitto 420s or Toyo Proxes. Any input is appreciated.
On the Droid X
JDub
607
Hooper, Utah
I ran a Cooper H/T Plus on my truck in that size, they worked really well on the street and hooked good at the track. Best part was they were relatively inexpensive.
Righteyeblind
712
Fairbanks, AK
420's all the way. Best tire I have had even better then the Proxes. The load rating is 120 which is like 3086lbs and is plenty for out trucks.
If you plan on towing a trailer a lot they wont be good. They are not LT so they will center wear pretty bad
dieseltwodoor
Apr 13, 2010
189
Alberta
If you are looking at the 420, you should check our the copper Zeon xst-a. I just put 30k miles on a set. They are super sticky and quiet. Awesome tire.
Sent from my iPhone using Tapatalk while riding porcelain.
